Question Cooling 3000d with 240 AIO ?
Nov 25, 2023
8
Hi I'm building in a 300d with a 7600 and 7800xt. The case has 3 120mm intake on the front and i have a 240 AIO on the top, the idea being that this PC can be upgraded in the future so alongside the AOI it also has a 1000w PSU. My question is whether to exhaust or intake through the AIO which is mounted on top. the front of the case and the top have mesh filter so i thought to have positive pressure i would intake through the front and AIO and have the rear exhaust running slightly faster than those intakes, the 7800xt is a Geforce WF so there are 3 fans which again are exhausting air being supplied by the lower front intake. Intake from the front then the AIO, GPU and rear fan exhausting seems like a lot to me, unless maybe i run the front fans a bit faster than the AIO and Rear exhaust? I usually set up a fan curve on my GPU so it ramps up as temps rise. Any thoughts would be welcome, thank you.
yess front set to intake and i have a spare fan for exhaust.
ASUS TUF GAMING B650-PLUS WIFI AMD Ryzen AM5 ATX motherboard​
AMD Ryzen 5 7600 Desktop Processor (6-core/12-thread, 38MB cache, up to 5.1 GHz max boost)​
Gigabyte Radeon RX 7800 XT GAMING OC 16GB Graphics Card - 16GB GDDR6​
CORSAIR VENGEANCE RGB DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory​
Cooler Master MasterLiquid 240L Core ARGB CPU Liquid Cooler - Dual Chamber Gen S Pump, Superior Radiator and 120 mm ARGB Fans, LGA 1700 and AM5 Brackets​
WD_BLACK SN770 2TB M.2 2280 Game Drive PCIe Gen4 NVMe up to 5150 MB/s​
Corsair RM1000x SHIFT Fully Modular ATX Power Supply - 80 PLUS Gold - ATX 3.0 - PCIe 5.0 - Zero RPM - Modular Side Interface - Black​
CORSAIR 3000D RGB AIRFLOW Mid-Tower PC Case – 3x AR120 RGB Fans – Three-Slot GPU Support – Fits up to 8x 120mm Fans – High-Airflow Design – Black​
Acer Nitro XV271UM3Bmiiprfx 27-inch Gaming Monitor - IPS Panel, 2560 x 1440, 0.5ms, 180Hz, FreeSync Premium, HDR 10, DP, HDMI, Height Adjustable​
