So, after all of the recommendations here and reddit to drop the FX 8350 from my build in favor of an Intel chip, I spent my days off reading into why and am finally convinced. This does mean I'll be scrapping my Sabertooth 990FX board (maybe selling it for ~$100? Basically unused. I'll look into that later).
Anyway, with that decision came a "fuck it, why not?" epiphany and upping my budget by up to ~50% to accommodate some vanity (As seen in the new part list, I'll try to get to them without getting too ranty) But more importantly, while I was looking into AIOs for the 8350 out of sheer overkill, they appear to be a minimal necessity for the 4790k, barring the Noctua solutions that will interfere with my vanity.
So let's get into the meat of it:
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($326.99 @ SuperBiiz)
Motherboard: Asus MAXIMUS VII FORMULA ATX LGA1150 Motherboard ($304.99 @ SuperBiiz)
Memory: Corsair Dominator Platinum 16GB (4 x 4GB) DDR3-2400 Memory ($254.99 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($207.89 @ OutletPC)
Storage: Western Digital VelociRaptor 1TB 3.5" 10000RPM Internal Hard Drive (Purchased For $0.00)
Video Card: Sapphire Radeon R9 290X 4GB Tr-X OC Video Card (2-Way CrossFire) (Purchased For $0.00)
Video Card: Sapphire Radeon R9 290X 4GB Tr-X OC Video Card (2-Way CrossFire) ($279.99 @ Newegg)
Case: Antec Eleven Hundred V2 ATX Mid Tower Case (Purchased For $0.00)
Power Supply: Antec High Current Pro Platinum 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($199.99 @ Newegg)
Case Fan: Cougar CF-D12HB-B 64.4 CFM 120mm Fan ($12.75 @ SuperBiiz)
Fan Controller: NZXT SENTRY 3 Fan Controller ($29.99 @ Directron)
Total: $2042.24
Generated by PCPartPicker 2015-04-22 18:00 EDT-0400
The big things here different from before;
-Already purchased one of the R9 290x's, I'll get the second one with the majority of the rest of this. Previously I included my current 60Hz/1080p monitor, took it out this time, because I'll likely be replacing it with one or more 144Hz monitors after the tower itself is built. The same with the peripherals (still looking for headset recommendations).
-Stopped being a retard with RAID configs and just dropped it to 2 500GB 850 EVOs with a new backup.
-Might as well lower the overall sound profile, especially if I can get the blue I wanted in the first place, though any other recommendations are still welcome for quiet+decent CFM fans
And then there's the new mobo, which is where the vanity (the armor) isn't that much more expensive than similar boards, with some red accents to the black which, in my opinion, look great with blue light. Also, potentially will make it easier to do a custom water kit if that's ultimately necessary.
BUT FINALLY WE ARRIVE AT THE POINT OF THIS TOPIC
Thank you for your patience.
According to Antec's site @ http://support.antec.com/support/solutions/articles/1000100885-kuhler-antec-case-compatibility-list, the Kuhler H2O 1250 should fit in the top dual 120mm fan slot, but nowhere else seems to confirm this. This unit concerns me on two fronts, namely the plastic backplate and the noise potential on extreme mode, because the fans cannot be replaced. Still, I like the ideas present with putting the pump away from the CPU itself.
That being said, if the 1250 supposedly would fit, are there any specific dimensions I should make note of to see if a Corsair h105 would work instead?
I'm also thinking of potentially push-pulling, either way. For better or worse, it seems like the only way to do so would be to mount the pulls on top of the case. Not necessarily opposed to this, as it'd just be another little project for me to work on to add some plastic or steel enclosure around them.
Or... are there any other 240mm AIOs I should look into instead?
Or... would a push-pull 120mm AIO be sufficient with no overclocking?
But, onto general airflow.
Since there's just going to be the two 2.5" SSDs and the one 3.5" HDD, there's not much resistance between the front intakes and the internal bay fans. Using my dead board, I confirmed that there'd still be room between the bay fans and this specific 290x.
That led to a somewhat strange realization that the manual for the Eleven Hundred suggested having the side panel fans mounted as intakes rather than exhausts. If I've already got the front intakes and the behind-the-motherboard intake, regardless of how I end up cooling the CPU, I'm left with positive static pressure. Sure, that's fine for the front intakes since there's already a dust filter there...
But the sides have no filters, which, yes, is something I could just add on, but then looking at the airflow - I'd have 4 case fans pointed at the 2 GPUs with their combined 6 fans pushing air down with the only exhaust being the PSU and the vents in the back and bottom of the case, with the latter being largely covered by the PSU.
Would flipping the fans to exhaust rather than intake help or hurt airflow and temperatures at that point? My real concern there is really the amount of heat potentially being dumped onto the second card.
As always, any advice or recommendations are appreciated.
(Hey look, you guys even got me to switch to an Intel! I do listen sometimes!)
Total: $2042.24
