Hi,
I have a Spec-01 case and I need new fans for it as the summer heat is getting my GPU to temps of 90 degrees. I am deciding to get SP and AF fans from corsair. I want to put 1 SP fan as intake on the front lower panel for the drive bay and another AF fan as intake on the upper front panel. Both 140mm. Then I will put 2 120mm AF fans as exhaust on the top and at the rear I will use the stock Spec-01 case fan as exhaust at the rear.
Is this air flow set up correct or does anyone suggest a change in it?
Thanks
Thanks
