I'm in the process of rearranging my case to open layout to get my new graphics card in.
To date, I've not been using the built in PWM fan hub, I've just been plugging fans into the motherboard (though I was giving the hub power)
I've got an Z390 Aorus Elite, and I'm cooling using a Corsair h115i with a front mounted radiator with fans behind (pulling), and plugged into the cpu_opt header (and the 2 radiator fans plugged into the block cable), and a single stock 140mm exhaust at the back (plugged into system fan 1/2/3_pump). And thats it.
Firstly, should I be plugged into cpu_opt or cpu_fan??
Secondly, any point using the PWM fan hub??
And thirdly, if not, does it need to be powered? Suspect not, but....
