I had some issues with my graphics card being very close to my cpu and causing the stock fan to go crazy without any load on the gpu, so I bought a Seidon 240m.
My case is a Cooler Master N600 which has the option of either installing the radiator on the side or the top. I also hear that the fans act as extractors on this water cooler, but this can be reversed? So, i'm a little lost also as to how I should set the fans up, on the top,of the radiator or underneath? On the side of the case or on the top?
My build is a Ga z77m dh3, i5350k, gtx970 asus strix, rm750.
Edit: There is no room for the rad to go above with the fans underneath it!
