Title mentions the case I have.
I have 3 Intake fans, two 120mm fans on the front and one 120mm fan fom the bottom. All three of them are connected to PSU due to its molex pin connection, so they run at 100 percent the entire time. I also have 3 exhaust fans, two 140mm at the top and one 120mm fan at the rear. These can be controlled via fan control. I want to know:
- Is this safe?
- At what speeds should my exhaust fans be since intakes are all at 100.
- Positive or negative air pressure.
Thanks in advance
- Is this safe?
Thanks in advance
