Cooling cpu oc
SweMan574
208
i use 8350 and want to oc it to 4.4-4.5 but i have a hyper tx3 and an aerocool x warrior black edition case. if i buy like a fractal design define r4 and a hyper 212 will i be able oc much? and is it worth getting a h100i water cooler?
fx 8350
8gb ram
550w xfx
gtx 760
m5ar97 r2.0
and is it worth getting water cooled gpu? not planning on doing that but what ever
Your air coolers can handle a 4.0-4.4GHz overclock, I'd overclock to 4.2-4.3 and keep the current cooler, the extra voltage needed and heat generated isn't worth the performance the extra 100-300Mhz is gonna make.
Good luck :)
Go further, i'd suggest a 4.3GHz overclock. Your temps would be fine and dont forget to let it do a stress test for stability.
Don't mess with it, you can reach your overclock by simply upping the multiplier and the voltage a bit, I read that the 8350 in some cases needs 1.35-1.4v to be stable at 4.5 on air coolers. Although it's different for every chip. so your gonna have to go slowly and only raise voltage when needed..
Latest posts
