Hello guys,
my problem is following: I'm running dual HD4870X2 cards (Sapphire) and recently I bought two of the Accelero Xtreme coolers and mounted them on my boys, hoping it will finally stop overheating. Well temperatures at GPUs dropped, noise dropped, all win. But when playing some game which equally uses both graphic cards (Call of Juarez - Bound In Blood now), it just burns down rapidly and PC shuts down, last line in the log of Everest program shows 122°C on GPU1 VRM.
I tought maybe one of the cards is bad and heats too much, removed the lower card, worked like charm (GPU1 VRM 71°C), switched the cards, same result. When I plug both, system overheats. My guess is because of the lower card's back just pump heat into fans of upper card which ain't cooled much then.
I'd be really grateful for any suggestions how to cool those mofos, I've applied AS5 under all heatsinks, helped a bit, but in the end it still overheats.
Case Lian-Li Armorsuit PC80, 3x 120mm intake fans, 1x 120mm exhaust at back (+ PSU exhaust), 1x 120mm exhaust on the top.
