Im currently having issues with my graphic cards. The temperature spikes from 50 to 90 C when palying games or randomly. At starts it had a constant 40 C and around it, all around.
I am looking forward to change the whole rig in the upcoming months but in the mean time i will have to use the current one.
A couple hour ago, after researching for a bit, i realized that my fan is the issue. When i turned the computer on the fan didn´t move at all even thought the graphic card gave image and pretty much worked but increasing in heat every 20 seconds. I turned the computer off and took off the card.
If you see the last comment about this idea of purchasing a case fan and ¨adding¨ it to the graphic card to cool it instead of the broken fan, do you think this might work for a couple of months? Which fan would do the trick? How could i attach it?
Thanks in advance for the help.
