Ok, so I recently bought several Scythe Kaze Maru 2 Slipstream fans or my computer in an effort to reduce the noise put off by my system when it is on. Took out 7 Antec red LED fans (noisy as all get out) and got most of my new fans put on. Some didn't fit due to space constraints of my case (Cooler Master CM 680II Advanced), but overall everything was fine....
until I turned it on.
I immediately heard the push fan on the front of my Megahelms CPU cooler hitting the fan blades. Well, I knew that wasn't good, so I spent 30 minutes playing with it trying to position it so it would not be hitting the Megahelms heat fans, but no dice. so now I just have one on the back pulling heat off the cooler, but nothing blowing cool air onto it.
Has anyone else run into this issue with a Megahelms, or knows how I might be able to fix this?
