Cooling for CPU without OC
odedgal67
61
Is cooling necessary for the i5 3450 or the 2500 running at their stock speed or the stock cooling coming with it is good enough?
Is there anything unusual about your case cooling or about where you store your case? Or is the location where you run the new system warmer than usual?
If that's no, the stock CPU cooler will be fine.
If there is something unusual about your case or operating location you'll want to monitor your system temps. Those will tell you if you're stock cooler is doing well enough.
You didn't mention which case you have.
And the case cooling works together with the CPU cooler.
Sharkoon T5 has decent case cooling setup.
Lo98L
I believe he actually meant IF your case has no fans.
Anyways, You'll fine with stock cooling. Even if your ambient is high, your CPU should still be below the max safe temp.
Which is probably 80/85c.
If it gets hot, i.e 80c + then you could always opt for an aftermarket Heatsink.
preferably the hyper 212+
