Cooling for Creative Geforce 2 GTS
Hoolio
291
I recently "aquired" a Creative Labs Gefore 2 GTS which is great replacement for my Voodoo 3 3500 TV in my second PC. Anyway Problem! It is lacking a fan and heatsink......
Could anyone recommend one to me, I need one that isnt going to stop me using the PCI slot adjcent to the AGP...can anyone point me in the right direction. The zalman ZM-50(the smaller of the heatpipe ones) looked perfect but it is not recommended for Geforce 2 GTS (arg!) so only the larger Zalman one is available that would stop me using the PCI slot next to the AGP (I think, also it is pretty expensive).
Thanks in advance
Julian
I dont think u wud need a Fan on the GPU. A simple Heat sink that the card came with is fine, IMO.
<b>thinking of a good sig. till then...</b><P ID="edit"><FONT SIZE=-1><EM>Edited by TheMask on 07/20/03 01:42 AM.</EM></FONT></P>
It doesnt even have a heatsink on it......can you tell me where I could get a suitable heatsink?
Would the Zalman ZM50 be fine if a small heatsink is all that is required?
Julian
Its weird coz, even my ASUS RivaTNT2 card has a small heat sink on it. Anyways, about ur query, i have no idea.
I would not run that card without a heatsink and fan. Let me do some research and I will find you one.
Asus A7N8X Deluxe
AMD Athlon XP 2700
512 MB Corsair Twinx
MSI Ti4600 8X
3DMARK2001SE 14654
Ok I found a couple of options. At directron.com they have a Iceberg 4 that says it will work on gForce 2. Also they have a Thermaltake Crystal Orb for VGA cooling but it doesnt state if it will work on a gForce2 or not but it looks like it will.If neither cooler will fit properly you can allways use Artic Silver Thermal Adhesive. But make sure you go to there web site and read directions if you havent used this stuff before. The Vantec is 8.99 and the Crystal Orb is 15.99. I used to have that same card it was a good one in its day. Good luck.
Asus A7N8X Deluxe
AMD Athlon XP 2700
MSI Ti4600 8X
3DMARK2001SE 14654
I would get a vantec part with some of the artic silver adhesive.
If you get one without a fan I would suggest one of those tornado PCI slot coolers that sit next to the AGP slot.. I used to use of of those on my GTS that didnt have a fan on it and it worked great.
Athlon 1700+, Epox 8RDA (NForce2), Maxtor Diamondmax Plus 9 80GB 8MB cache, 2x256mb Crucial PC2100 in Dual DDR, Geforce 3, Audigy, Z560s, MX500
I'll sell you a notebook CPU cooler that's the same size as most GeForce2 coolers but of far better quality, for $5 plus shipping. I've sold a few of these on eBay, all happy customers. They are around 1/4 inch thick, and can be affixed with any thermal epoxy (including the most common type, JB-Weld, available at Wal-Mart).
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
