I've recently built my own PC and I have a few questions. I'm not quite satisfied with how my Hyper Evo 212 is cooling my i7-4790. Whenever I use Pirme95 - for 15-20 minutes; the CPU hit's a max of 69 degrees. I know the max temp the CPU allowed is 72.7. But; I'm not happy with the temp. I would like to get it into the low-mid 60's if at all possible with this CPU. Any cooler suggestions to better fit this CPU, to get it to 50-60 degrees at max load?
Non-gaming: Temps idle at 30-38 degrees
Gaming(Playing GTA V; etc.): Temps are at 50 - 64 degrees (50ish% CPU Usage)
Case is NZXT M59 <-- Terrible case for big items. 😛
My specifications:
CPU: i7-4790 3.6 GHZ - (4.0GHz @ Turbo)
CPU Cooler: Cooler Master Hyper 212 Evo
GPU: EVGA GeForce GTX 970 SuperClocked ACX 2.0 4GB
Motherboard: MSI Z97-G45 Gaming Motherboard
RAM: G.Skill RIpjaws Series X 16 GB(2x8) @ 1866 MHz
Hard Drive: Seagate 1TB 7200 RPM 6.0Gb/s HDD
Case: NZXT M59
Fans: 2 120mm 59.1 CFM Fans
My specifications:
Case: NZXT M59
