Cooling Help Needed
JGunnzz
61
I need urgent help with cooling my computer, it gets very hot where I am in the summer and my computer has just the stock fans. I was wondering if someone could put together a list of cool yet parts to cool the components in my n200(Micro ATX). So, I 2 intake fans, a CPU cooler(I was leaning water cooled) and a top 140mm exhaust fan. I of course don't want to spend to much money. Could someone please help?
Thanks in advance.
The H60 is pretty cheap $(60-65) and will Keep your CPU very cool, if you are not overclocking, the get the h55 which is even cheaper and still will keep your CPU nice and cool. ($50-60) for intake fans you will want a high airflow fan, Corsair makes slightly expensive ones, cougar makes more affordable ones which are as good. for the 140mm top fan you could get a cougar one too, or a single corsair high performance high airflow fan. the cougar fans range from $15-25 the corsair ones are around $20-30.
Man, you are really on top of the cooling part of the community. Yeah, I was for sure looking at the h60 for the CPU, and the AeroCool dead silence line for the other fans. Do you know if those are any good? Thanks again for replying!
