Cooling Loop monoblock not compatible with mobo's IO shield... HALP!
had a quick look
yes looks like you either remove the io shield
or chop off any/possibly 2 of them--heatpipes that come from the io shield if you want to keep the io shield on
ie--its the heatpipes attached to the io shield that get in the way of the monoblock--not the actual shield
though you would have to double check this on asus forum to be safe
if your motherboard can take a monoblock
then there should be one thats specifically for your board that fits ok
or it should say you need to remove the io shield
but either way it has to be a monoblock for the exact motherboard you have
they are not interchangeable with all motherboards--ie universal
In the desc. of the monoblock it says that its exculisive to my mobo. Yet after scrolling down it says that its not compatible with the I/O shield of that motherboard.
https://www.ekwb.com/shop/ek-fb-asus-r5-e10-monoblock-rgb-edition
nice looking block
not familiar with your board
but it may be that the monoblock itself covers some of where the io shield is
which would mean removing the io shield
try on youtube to find some one who has fitted one to see
had a quick look
Thanks anyway... I'll do a check with Asus support
