Justin McCrea :
My apologies its the mid tower, i allready have all mentioned components (hd 7750 and yes its single height cause the cpu fan shroud gets in the way.) I have a logi sys 550w psu, core 2 duo e8400 3.0 ghz win 7 64 bit, it's my temperary gaming pc till I get my build done but I still would like to invest in the cooling as when I am done with my build I will be giving this machine to my nephew. sorry I was refering to my hard drive.
Justin McCrea,
From my experience with an Optiplex 740 in the slim desktop case the stock fan and Aluminum heatsink worked well with a 3.0GHz dual core AMD X2 64.
But, as your test ran quite hot, or think you're nephew might upgrade to a quad core CPU, as this thread has discussed, there are few options unless you add fans. You might start with changing the stock Aluminum heatsink- it's a casting with vertical fins in a V pattern, for the Copper/Aluminum version that has parallel plate fins with a Copper tube running through from bottom to top. As far as I know, the CU/Al heatsink was supplied when there was a higher clock speed "Extreme" or a quad core CPU. Here's an example>
http://www.ebay.com/itm/Optiplex-745-755-760-320-330-360-Heatsink-With-Shroud-/261196689364?pt=US_CPU_Fans_Heatsinks&hash=item3cd0892fd4&nma=true&si=hx0slaT%252B8%252BFhIQYLLiGpKQYv5tg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I saw on eBay completed listings what appeared to be an all-Copper heatsink which would probably be the best for heat transfer, but that one might also be the one for the slim desktop format case.
I
think - not absolutely positive- the heatsink shrouds are the same- there are a series of holes on the top that with the stock heatsink are empty and with the Cu/Al the Copper tubes show projecting tips in those holes.
as you can see form the eBay completed listing, these heatsinks / shrouds are seen often on Ebay- are not expensive- I see the Optiplex 755 Cu/Al including shroud for as little as $10-15. I bought a similar- if not exact set for a Precision 390 just this morning for $10, shipping included, as that 390
may be changing to a quad core.
Check the condition (RPM) of the CPU fan too. You might also see if there's a software control that could run the CPU fan faster. I was thinking of adding a 92mm fan to back of the case of a Precision T5400, but the PCI slot fan as suggested by Cazalan looks interesting and space efficient.
Cheers,
BambiBoom
