Cooling pad for a latop
Hi guys, I was looking for some help with a cooling pad, I have an ASUS zenbook, specifically this one (https://www.asus.com/ca-en/Laptops/ASUS-ZenBook-UX430UA/). The fan/ where the hot air goes out from is the top (right below the screen, the area where the screen display connects to the lower half (keyboard). Could you recommend a cooling pad based on the position?
Please list Amazon products if possible.
Be aware that the UX430UA does not have any intake vents on the underside of the laptop. The vents are actually around where the hinges are.
Since the chassis is made from aluminum, I assume the laptop is using a chassis like a heatsink to keep the insides relatively cool. Any cooling pad that is blowing air at the chassis should help cool the laptop.
I use the following cooler for my Dell Insipron 7559 which lowers the temperature by 5c. The laptop has a plastic chassis and there are air vents on the underside of the laptop.
https://www.amazon.ca/DeepCool-Cooling-Multi-Core-X6/dp/B00B3RZ298/ref=sr_1_1?ie=UTF8&qid=1534537314&sr=8-1&keywords=deepcool+multi+core+x6&dpID=41mlaweAADL&preST=_SY300_QL70_&dpSrc=srch
