E erik8thw Distinguished Mar 2, 2013 162 0 18,680 Jul 27, 2015 #1 I found that the internet speed is affected because of overheating router. Can I use a cooling pad to cool my router all day? The cooling pad is NOTEPAL U STAND mini and the router is TP-W8980.
Solution kanewolf Jul 27, 2015 There are USB powered fans. If your router has a USB port, a fan on a flexible stalk will allow you to point it directly onto the hot areas.
jsmithepa Polypheme Jun 14, 2014 13,091 264 60,840 Jul 27, 2015 #2 Router doesn't care what cooling method, it just wants to be cool? 😀 Personally tough, I would open the router, vacuum it, and see if I can add heatsink to the big hot chips. Do you have a thermometer gun? Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 38,644 3,806 156,790 Jul 27, 2015 Solution #3 There are USB powered fans. If your router has a USB port, a fan on a flexible stalk will allow you to point it directly onto the hot areas. Upvote 0 Downvote Solution
