Question Cooling Pad IETS GT600 or Llano V12/V13 ?
Aug 6, 2024
Hi there,
I'm struggling to decide between these two cooling pads for my laptop. Here is what I've found online so far:
IETS GT600 V1/V2:
  • Thicker foam with magnetic sealing (that Llano lacks)
  • Quieter at 2800 rpm (max fan speed)
  • 2 superposed dust filters (Llano has 1)
Llano V12/V13:
  • Slightly better cooling performance
  • Faster cooling
Can someone confirm these claims about the Llano ? Any feedback will help, thank you
Can you please state the make and model of the laptop? In fact, you might want to see if the bottom of the laptop has vents. Laptops without any vents at the bottom of the laptop will only offer minimal returns after adding a cooling pad.
To add, both cooling pads look the same except for the front panel inerface.
