Question Cooling recommendation for ZOTAC RTX2060 Mini
orodruin
48
4
10,535
Hi Guys,
I am using Zotac RTX2060 Mini. Unfortunately, the cooling is not good. What would you suggest I do for this graphics card?
If I connect liquid cooling with NZXT Kraken G12, can I mount it without any problem? Or Arctic Accelero Xtreme III or IV supports for cooling?
If I have a chance to connect NZXT Kraken G12, it would be better because I have Zalman LQ310 liquid cooling compatible with G12.
Ralston18
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age condition.
Case, fans, fan arrangement?
Quantify "cooling not good". What temperatures are you seeing and under what conditions?
orodruin
48
4
10,535
Be Quiet! SilentBase 802 White,
PSU: BeQuiet Stairthpower 850 80+ Gold.
Motherboard: Asus X570 Crosshair VIII
Processor: Ryzen 9 5900x
Ram: Gskill Tridentz RGB 4x16GB 3200 Mhz
Radiator: Asus Strix LC360 The radiator is top mounted.
Fans of BeQuiet SilentWings 3 pcs. It expels the air from inside.
The chassis exhaust fan PureWings discharges the air inside 14cm from the rear.
Three 14cm PureWings fans in the front blow in fresh air.
All fans are connected to the motherboard.
All hardware is 6-7 months old.
And Windows 10 21H1..
They are not worn out. While playing normal games, the temperature of the video card can rise to 83-84 degrees. I wanted to lower the graphics card temperature.
