This system was originally built last summer with the help of many Tom's Hardware users. I truely appreciate all the assistance, it has served me extremely well in my gaming and I would like to make a few upgrades.
I need 24gb Ram Upgrade, Hard Drive (I'm currently running everything off of the SSD), Cooling Upgrade, 1-2 Additional GPU's for Monitors 3&4.
Approximate Purchase Date: Immediately
Budget Range: Already spent around $4500. Would like to spend no more than $1,000 more.
System Usage from Most to Least Important: (e.g.: Folding@Home, gaming, surfing the internet, watching movies)
Preferred Website(s) for Parts: newegg.com or amazon.com
Country of Origin: United States
Parts Preferences: It's an Intel System with NVidia GPU's.
Overclocking: Yes
SLI or Crossfire: Yes for some applications.
Monitor Resolution: Currently use 1920x1080
Additional Comments: The items below are what I have currently installed.
Original Build:
CASE: COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225&Tpk=RC-942-KKN1
MB: GIGABYTE GA-X58A-UD9 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 XL ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128446
GPUS: 2 x GIGABYTE GV-N480D5-15I-B GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125319
PSU: Antec TPQ-1200 1200W Continuous Power with PowerCache Technology SLI Ready CrossFire Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371032
CPU: Intel Core i7-980X Extreme Edition Gulftown 3.33GHz LGA 1366 130W Six-Core Desktop Processor BX80613I7980X
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115223
SSD: Crucial RealSSD C300 CTFDDAC256MAG-1G1CCA 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148363
RAM: G.SKILL PI+ Turbulence 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL6T2-12GBPIS
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231354
CPU Cooler: PROLIMATECH Armageddon for Intel LGA 1156, LGA1366, LGA775, 6 Dual Heatpipe, Twin Tower Type Quiet
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242005
I have ordered the following RAM for upgrade, it has lower timings than my current 12gb, but figured 24gb of slower RAM is better still: http://www.amazon.com/gp/product/B0033C2A50
My GPU's have been discontinued I'm assuming because of the heat issues etc. I would like to add 1 or 2 more GPUs and monitors to my system. I'm not sure which GPU's would be appropriate to use with the 480gtx's.
Also to keep down heat, I've considered liquid cooling.
However I really don't know what would be my best cooling option. Any advice would be appreciated.
Overclocking: Yes
Original Build:
