I've recently managed to gather up some extra money and decided that it would be time to fix a massive problem on my PC. The R9 390x runs extremely hot on some games and I can only play those games for max. 1 hour before the card starts heating up like crazy. I have to keep my case sidepanels open since it helps to some degree. But that causes a ton of noice. I recently hit 96C° on Rust and Overwatch only after 30mins (fans at 100% from the start) I have about 100 euros to spend and it doesn't matter if it is water cooling or air cooling. I would just like to have my computer case shut, Coolermaster R5 if I remember right. I do live in Finland so I wont be able to order from the US or Canada.
Thank you.
Thank you.
