[SOLVED] Cooling unit for Zotac 1060gtx 3GB
Dec 23, 2019
7
Hi there,
I have urgent need of adding a cooling unit to my Zotac 1060gtx 3gb (or buyable fan replacements).
Can anyone suggest a cooling unit compatibile with this specific card? (water or air cooling are both fine as long as they are compatible)
Thank you
Broken fans are: Apistek ga81s2u (4 nails)
Here are the card and the fans:
These look like them, though they say for Zotac GTX 960 they are both 75mm and 4-pin.
https://www.ebay.com/itm/75mm-GA91S...hash=item443a99e2f6:m:muarN7_DTF2YNrYIAf_vDkA
They are from China and would take at least 2-3 weeks to receive.
thanks for the help man!
I found out these ones and ordered them, they should arrive the 30th of december which is not that bad. They're for the zotac 970 but should be the same model aswell
https://www.amazon.it/dp/B07QLLS1D8/ref=pe_3310731_185740161_TE_item
