I use the x41 to cool my 1080ti for about 10 months now. It worked great up till about 2 months ago. I have a push-pull setup with both fans at around 8-900 RPM.
The first 8 months the water temps were 3-4 degrees lower than core temp and the performance was great. Now the disparity is as high as 15 degrees! So the heat does not get transported obviously. First I thought the liquid metal degraded so I cleaned everything up and replaced it with a healthy dose of MX-4 from Arctic Cooling, non conductive. Nothing changed. Even if not as high performing as liquid metal I think it should perform better than that. The performance is identical to before.
What can I try next before sending the unit back?
