Cooltek UMX2 PC Case Packs Front-mounted Power Supply
This is in the US but marketed under Rosewill (at least at Newegg)http://www.newegg.com/Product/Product.aspx?Item=N82E16811147201
I like the looks and style of this case with the slim drive and the bottom to top air flow. But I would be worried about the PSU as there is no place for it to intake air from outside the case, and it looks like the only place for it to exhaust is out the bottom.. which is right next to the 120mm intake fan, so you will be pulling any warm PSU air right back into the case. I could be wrong, but I couldn't find any pictures of an assembled build.
It seems like having two fans at the bottom would cool the video card pretty well but not the rest of the components. I do like the sleek design though.
I like it but airflow's going to be a nightmare for hot running components. Would be great for a normal build, too bad it costs so much.
Nice.. clean billable case. I dont like the psu in front. Or more like I can't stand psu's anywhere but on the back bottom. I had one that popped right over the cpu (this was back in the day) and I stopped buying cases for myself that have the psu's anywhere but underneath and behind. Also another reason I dont buy AMD ANYMORE.
You don't buy AMD because back in the day you had top mounted PSU (like everyone else). O... K...
