COPUTER CASE THAT WILL HOLD 2 POWER SUPPLYS
Some cases which have two PSU bays, that I know of:
AZZA Genesis 9000
Cooler Master ATCS 840
Enermax Fulmo GT
Lian Li PC-A70F
Lian Li PC-A71F
NZXT Khaos
Rosewill BLACKHAWK-ULTRA (similar to Enermax Fulmo GT)
I second using the Genesis 9000. It's different from the rest because both PSU areas are on the bottom. One is actually in the front of the case and simply has a pass-through cable that allows you to plug it into the back. Plus, it's an awesome case, which I assume you want since you're building a system worthy of two PSUs (or 2 systems in one case?)!
In fact, if you are thinking of two systems in one case, you could always go for the super huge cube cases like the MountainMod cases or maybe this one: Lian Li PC-343B Modular Cube Case (http://www.xoxide.com/lian-li-pc-343b-case.html)
Totally appreciate your input. Building an audio and video editing beast for a producer friend of mine. He does amazing things with a windows pc.
