I have a SATA 2.5'' HDD in USB 3.0 enclosure (compatible with 2.0), when I connect my USB 3.0 hub with external power supply to one of my USB 2.0 ports and connect the HDD to that hub everything seems to work until I try to copy any bigger file to it.
It always hangs at some point, regardless of the operating system (windows XP, windows 7, linux (debian)). After waiting a long time linux shows "IO error". It doesn't really disconnect, it just starts working really slowly, even showing contents of eny directory takes a few minutes when it happens. The same HDD works fine when connected directly to the same USB 2.0 port as the hub, and when connected through the hub to USB 3.0 port (in my laptop, my PC has no USB 3.0 ports and very few working USB 2.0 ports).
I did a full disk scan using HDTune and it showed no errors.
The only revelant thing that shows on google is my question on superuser, with 0 answers.
I can't connect my HDD directly to any USB port because I don't have any free working ports left on my PC, so I always have to disconnect something. And even then some ports just refuse to give enough power for the HDD.
Is there anything I can do to fix the problem? Is it some expected incompatibility or is it faulty HDD enclosure/USB hub? Both are still under warranty.
Edit: can it be related to the hub not being OTG compatible? (I have no idea what it actually means)
