[citation][nom]warezme[/nom]Whats wrong with 3.8Ghz? Its good overclock, with minimal stress on all your junk. Why folks have to push their stuff to 4Ghz or higher stressing the hell out of the hardware just for a couple more lousy FPS. I have an X58 that can push voltage and run at 4.2Ghz but voltage and heat requirements go up way to much and only give me a few more FPS. Its not really worth it.[/citation]
Uh, d00d, let me see if I can explain this in terms you can understand: 1.45V has been used for 45nm Intel processors long enough that it's now a standardized OC test voltage. There are many reasons for it having become this standardized test voltage, including the fact that it's considered the maximum safe voltage in some Intel documentation, that it's the maximum voltage most processors can run using above-ambient cooling, that it's the spot just before power consumption spikes, etc. It makes sense, and because it's NOT extreme, was never extreme, was never intended to be extreme, and is in no way extreme, it's something that any overclocking motherboard should tollerate.
We understand that cheap boards exist. If you're going to market a cheap board towards low-cost overclocking, you need to put in over-current protection. If you're going to market an even cheaper board with no protection, you need to disable the overclocking features.
It's one way or the other, when it comes to overclocking either do it right or don't do it at all. Half-fast solutions aren't acceptable in the overclocking market. It's a quality issue, and Tom's Hardware has tested MANY high-quality budget parts in the past.
There's no excuse to cut quality when you can instead cut features to produce a cheap product. IE, if you really really really wanted to make a board that could only do 1.35V before blowing the VRM, and really wanted to sell it without overcurrent protection, you'd really really really want to limit the BIOS settings to 1.35V. Because when you didn't, you'd get caught with your pants down by a site such as this one.
To not report such a finding would be proof of a lack of integrity. To give up testing at this setting would be to cave in for low-quality products at the expense of not revealing the superiority of high-quality products. The reader isn't served, the industry is disserviced, everyone loses.
[citation][nom]Proximon[/nom]Thanks Crashman, this goes towards a resolution and at least we have a few lower budget boards now that look to be relatively safe.Didn't you use a different PSU last time? Playing it safe with the higher quality 850HX maybe?[/citation]
Nah, same power supply since September, might have forgotten to change the model in the setup table.
