Core i7 Build 1200 Dollar Budget Need Help!! (Crossfire Ready)
here is a build for $1,169.91 without shopping and without mail in rebates
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
SAPPHIRE 100269OCSR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - OC edition - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102831
Tuniq TX-2 Cooling Thermal Compound - Retail (this is one of the best thermal compound u can ever find)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835154003
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model OCZ3P1600LV6GK - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Noctua NH-U12P SE1366 120mm SSO CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608007
Prices from newegg.com
* 181244ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
* 181244Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
$524.98
$109.99
CORSAIR CMPSU-850TX 850W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready Active PFC Power Supply - Retail
$144.99
SAPPHIRE 100270SR Radeon HD 4850 X2 2GB 512-bit (256-bit x 2) GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
$279.99
Chose this video card based on this http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/13847-evga-geforce-gtx-285-1gb-ssc-edition-review-19.html and http://www.driverheaven.net/reviews.php?reviewid=657&pageid=5 .
Also the price is great, should perform amazing in GTA4 and in Crysis
$74.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM
$74.99
$24.99
Total: $1,234.92
Without MIR's
NEVER get a rosewill PSU. They suck. THEY SUCK!
Also, the case was the deal of the day either yesterday or the day before. You could've saved 10$. Go with Ssassan's rig. It'll do fine in Crysis but don't get a 4850x2 when you can get a 4890 (or GTX 275) for the same price. One GPU beats two smashed together in plastic casing. Good luck.
Both of those reviewer sites you posted are BS. When does a GTX 295 AND a 4870x2 lose to a GTX 285.
The GTX 275=GTX 280= 4850x2. Gtx275=4890. Either would work.
