News Core i9-13900K and RTX 4090 Run at Sub-Zero Temps Outside
Nolonar
231
82
18,760
Need to change that fluid up, anti-freeze(50/50) is good to -38°C, maybe good enough for this current application.
She already knows.
From the article:
But at -30 C and -40 C, liquid in the closed-loop 360-mm liquid CPU cooler froze and the device simply stopped working. To cool down the processor, she had to install Noctua's NH-P1 passive heatsink and build a monstrous air compressor out of dozens of high-pressure server fans that created sound that was as horrific as the compressor looked.
frogr
48
23
18,545
PEnns
289
217
5,060
"But such sophisticated coolers apparently aren't necessary if the temperature falls between -30 degrees Celsius to -53 C (-22 degrees Fahrenheit to -63.4 F) outside...."
Those lucky Mongolian gamers, playing outside in balmy sub zero temps!! What's next, Intel lava-like processors are great for playing at absolute zero temps on Neptune??
Reactions: bit_user
bit_user
Illustrious
Ambassador
Why is it so surprising that it worked? If you don't let the PC get too cold before turning it on, then I'd expect it to.
Um, why couldn't she just use a normal Noctua tower cooler with its own fan? Maybe she tried the passive cooler to see how well it would work on its own, and didn't have ready access to, or funds to buy an active tower cooler?
Could there be some issue with fans' bearings freezing that maybe doesn't apply to the server fans?
Reactions: cyrusfox
Howardohyea
Commendable
May 13, 2021
261
64
1,790
My thoughts exactly, if there isn't any liquid components (like AIO) in the PC, it should function more or less just fine regardless of temperature.
That reminded me, the liquid in the vapor chamber may freeze, but when it thaws I think it's going to be alright.
Reactions: bit_user
bit_user
Illustrious
Ambassador
BTW, my comment about fan bearings was in relation to some of them being "fluid dynamic bearings", which I'm guessing use oil as the fluid. Oil gets viscous, at low temperatures, which could prevent the fans from spinning. Even the amount of oil in ball bearing fans could be an issue. Maybe that's why she had to use high-torque server fans? Otherwise, it seems like a fairly random thing to do.
There probably is some temperature that's so cold the "far" side of the vapor chamber might not be able to stay unfrozen, leading to all the fluid collecting as icicles there, instead of flowing back along the walls. The walls themselves don't conduct heat very well, limiting the ability of them to thaw the frozen part.
