Core Temp says my CPU has reached a Max of 160 degree celsius. Why?
AMD Vagrant
43
I bought a new computer recently 2-3 weeks ago.
AMD 8350 CPU
corsair h100i CPU cooler
gtx 970 G1 GPU
I just noticed today when I was leaving core temp open, that the maximum temperature my CPU is reaching is 160 degree celsius. How is this possible? is it a bug in core temp or is my CPU going to die? Isn't there some sort of fail safe that would turn the CPU off if it reaches that limit. I think for the 8350 the limit is around 60-70 Degrees.
I'm pretty sure I put the cpu into the socket correctly but I'm a bit worried I made a mistake with the Corsair CPU Cooler, it went on fine but it may have moved ever so slightly when I put it on top of the CPU. I saw some guy put it on, on youtube with one hand. So I guess it should be fine.
At idle "Core Temp" says my cpu is anywhere from 10-19 degree. Unload, from memory, it's around 30 degrees.
So any Ideas about the 160 degrees?
Cheers
Core temp does not measure AMD FX-8350 accurately. I had the same reaction when I tried using it. Don't worry! Use another program such as open hardware monitor:
http://openhardwaremonitor.org/downloads/
You need an external removable hard drive with the system installed I use Acronis to clone the disk from raid to any build i did.
A memory check first, a disk scan for errors is the first things that i do, if you are in windows a "sfc /scannow /offbootdir=d:\ /offwindir=d:\windows" if some system files are damaged. A really good antivirus is needed and some reboots to update scan the system for viruses.
The external disk is also helping me defrag the disk much better.
Thanks Alfrodo, I've downloaded the program and it seems to be a bit more accurate, although I haven't run into the same error again.
core_dumped, not sure I quite understood your post, sorry for the late reply though, I thought disk defraging is only useful after a HDD has had a lot of data on it and then had the data deleted. Not to sure about the memory check paragraph either.
