Core2Duo Overclocking Guide by Wusy
Vlip
The overclocking guide by Wusy published was excellent but covered only E6000 series processors. Could someone publish a similar guide but for E4300?
Thanks!
I think what the OP was leading to was the 800Mhz FSB and the diff multiplier allowing a slightly easier 1:1 OC..
Is that what you were trying to get at Vlip?
Hey all, thanks for all the input. The main thing I was getting at are the voltage and FSB starting point recommendations in the guide.
I must be doing something wrong or I got a bum mobo or cpu. I tried going right to 266FSB with voltages in auto and the system fails to boot. So, I went back to 200 FSB, then 205, then 210 and fails to boot at 210. I'm going to try setting voltages to manual but leaving default values. I'll post back when I've tried that.
Vlip
