I just wanted to check if anyone else was having a thermal issue with the 8600k where cores 3-5 (especially 3) showed higher temperatures than cores 0-3, since my core 3 almost was 20 degrees celcius higher than the other cores while under load
Image : https://imgur.com/a/rcjiida
I had my i5 8600k Delided by a reputable delider on eBay (Asked him if he was certain he covered the whole die, and he said he was), Even changed the thermal paste on the CPU twice with Arctic MX4 and Noctua NH H1, with my Noctua U9S (x2 92mm Fans)
