Correct data cable for project
eddyb95
49
Hello,
I have a 30 floor building that i need to run a data cable up in a daisy chain inside an electrical riser. The daisy chain stabs off at each level to a controller that it will collect data from and send it back down to a CAN Moudle system.
I have run into a problem where the can module is not able to communicate with the controllers after about the 9th floor (roughly 60m). I am running cat5 cable and i am hoping that there is a better cable that i can use that will get the signal all the way to the top.
Any help is grately appreciated.
