Correct F_USB2 pins for ECS H61H2-M2
Minero
Hey guys. I am a novice on motherboards and need your help in trying to figure out which F_USB2 ports connect to which cable. For starters, the manual of my motherboard ECS H61H2-M2 gives the 9 pins as USBPWR, USB_FP_P1-, USB_FP_P0-, USB_FP_P1+, USB FP_P0+, GND and NC. The cables that I have to connect on the other hand are written POWER SW, POWER LED+, POWER LED-, H.D.D + and -, RESET SW.
Now I know I am supposed to follow the manual on putting these on, but as you can see there nomenclature is different between the two, can you please help me as to which cables goes where?
Thanking you in advance.
Well most of the pins on the front panel connection need 2 pins / wires
According to the manual the power would go on pin 6 and 8 (+ on 6 and - on 8)
Reset on pin 5 and 7. And the hdd led (+ on pin 1 and - on pin 3)
Hi Paul,
The cables POWER SW, POWER LED+, H.D.D + and RESET SW are from the front. So I want to know which pins they must be put on my ECS motherboard because the Manual uses other names like I have indicated in my main message.
Thank you so much Paul. Now where does Power Led + and Power Led -. I know what is left out after your reply is 2 and 4, I just want to know between positive and negative, which one goes where. Thanks in advance again.
