Hi, i'm going to build new PC using ASUS B560M Prime-A motherboard link. I will be using Intel i5 10400 LGA 1200 Socket. I have couple questions:
1: Is there an order in which motherboard drivers should be installed, or it doesn't matter?
2: Which drivers are mandatory and which are optional? I don't want to install optional drivers/software for my motherboard, they are annoying and take extra resources.
I can figure out which are optional excluding some from "Chipset" category, can you help me with that?
These are listed under "Chipset" section: (Windows 10 64bit)
Intel Consumer ME driver V2047.100.0.1039 For Windows 10 64-bit.
Intel Serial IO driver V30.100.2051.37
Intel SerialIO Software V30.100.2042.1 for Windows 10 64-bit---(WHQL).
Intel Management Engine Interface V2040.100.0.1029 for Windows 10 64-bit---(WHQL).
Intel Gaussian and Neural Accelerator Driver V2.0.0.1097 for Windows 10 64-bit---(WHQL).
Intel Chipset Driver V10.1.18634.8254 for Windows 10 64-bit---(WHQL). <----- This is the only one i can understand needs to be installed, what about the ones above?
3: Side question: I'm assuming i should install motherboard drivers first and update windows later, is that correct?
