Helping a friend as his garage metal walls are blocking the wifi from his home router to the garage
He has a cat 5 cable ran when built used for his cameras
I have an unused Linksys WRT54G router to turn into an access point.
Optimum service provider.
cant access Optimum router to verify all info but ipconfig gives the router ip address.
set second [access point ] router to DHCP disabled
local ip to xxx.xxx.x.254
set SSID to same as home router as per https://www.wikihow.com/Convert-Linksys-WRT54G-to-Be-an-Access-Point
set key to same as home router as per same
this guide says home router should be channel 1 set access point to channel 6 or 11 etc.
default was channel 6 so I figured I was good
save settings
connect to cable from home router reboot and reboot home router
All we can get is still the weak signal from the home router
after several attempts to access the router with my lap top which times out, I reset router and cabled to my laptop with original ip 192.168.1.1
applied all settings again, but forgot to duplicate the SSID / key
restarted again.
Now it shows up as "linksys" open and the signal is found on both phones and my laptop plus his tablet.
again cant access router to change security to wpa2Personal etc, and match SSID/key
reset and try again but when the SSID /key is set same as home router the only signal is the weak inhouse router signal
could it be as simple as the channel is wrong? or is the instructions wrong for setting the SSID/key?
I am an amateur, but thought I could set this up, but I guess I am just dangerous, lol
any suggestions would be appreciated
thanks
doug
save settings
restarted again.
thanks
doug
