Question Correct timings for my ram? Corsair can't help me
cheekykid
29
I am looking for some help to find which are the correct timings for my DIMM's and Corsair doesn't seem to know. Their reply is: "Unfortunately, we are unable to assist with providing the specific timings for underclocking/overclocking memory kits. Outside of the applications suggested, I advise reaching out your motherboard's manufacturer for further assistance. Enjoy your day!"
I have four 16GB ‎CMH32GX4M2Z3600C18 paired with my AMD 5900X. Due to my cpu I can only run them up to 3200Mhz.
"I think" the correct timings for 3200Mhz are as follows:
  • CAS Latency (CL): 16
  • RAS to CAS Delay (tRCD): 20
  • Row Precharge Time (tRP): 20
  • Cycle Time (tRAS): 38
  • Set the DRAM Voltage to 1.35V.
    I am not sure what should I put for tRCDWR which BIOS has set it at 22.
    Does anyone know if am on the right path here?
KingLoki
Upstanding
Jul 10, 2024
479
75
270
Yeah should be fine. Boot it up and run cpu-z program and check memory inside there. When you are overclocking memory to push it faster, the timings normally loosen up anyways.
