Corrupt registry recovered issue please help.
Dreadbeard
813
25
19,010
Hey guys. My issue started when i left my pc idleing whilst i was doing other things, i came back to find it had crashed for no aparent reason. It looks like a corrupt registry, twice within a month now.
Its telling me i get unhandled expetions in my .net framework.
Such as.
I have no idea whatsoever what this issue is, and i get this whilst opening event veiwer trying to locate the cause of my issues.
Can anyone shed some light on this please?
Another error pops up upon trying to veiw my event viewer. saying the following
"Unhandled exception has occurred in a component in your applicaiton if you click continue the application will ignore this error and attempt to continue"
"Attempted to read or write protected memory This is often an indication that other memory is corrupt"
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.RichTextBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Microsoft.ManagementConsole
Assembly Version: 3.0.0.0
Win32 Version: 6.1.7600.16385
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.ManagementConsole/3.0.0.0__31bf3856ad364e35/Microsoft.ManagementConsole.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
MMCFxCommon
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/MMCFxCommon/3.0.0.0__31bf3856ad364e35/MMCFxCommon.dll
System.Configuration
Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EventViewer
Assembly Version: 6.1.0.0
Win32 Version: 6.1.7601.17514
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/EventViewer/6.1.0.0__31bf3856ad364e35/EventViewer.dll
MIGUIControls
Assembly Version: 1.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/MIGUIControls/1.0.0.0__31bf3856ad364e35/MIGUIControls.dll
System.ServiceProcess
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceProcess/2.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.Web
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
And another one.
mscorlib
System
MMCFxCommon
System.Xml
System.Drawing
EventViewer
MIGUIControls
System.Web
enabled.
For example:
<configuration>
</configuration>
