Question Corrupted Flash Drive Firmware
Sep 7, 2023
Hey guys, so I have this quite old 1gb Kingston DataTraveller II Plus migo and I tried using some old kingston software with it on windows 10. Unfortunately the software crashed in the middle of a very low level action and the firmware on the microcontroller got corrupted. I've found out that my flash drive is using the Phison 2151-53 microcontroller using this utility.
I then tried searching the same website for a version of Phison MPALL compatible with my model, but it is nowhere to be found. The only tool I found on the internet that lists my model as compatible is the Phison Preformat here. I unfortunately wasn't able to get this to work either as even after putting the device name in the swbn.ini file the low level format would always fail. Can anyone help me with finding the right program for restoring the firmware? I've really tried searching everywhere, but the most helpful resource so far was the usbdev.ru website. I just use google translate on it since I don't understand russian. Thanks for any help and if you need any more info I'll be happy to provide it. :)
edit1: And yes I know that doing all this isn't really worth it for a 1gb flash drive, but I just find the form factor very convenient and easy to carry around on a keychain.
I've bought a couple of these for personal use and also recommended them for my clients. IMHO, you're just wasting resources on something that's a relic. If you could provide your location, your budget and a preferred site for purchase, would help the community in suggesting pen/thumb drives that are convenient to carry on a keychain.
