My server, starte experiencing corruption problems when I removed a PATA drive the other day.
I took the drive off to try it on another machine. When I booted back up, aplications started crashing, it had to check all the disks for consistency etc.
After living with it for a few days, it wouldn't boot any more with a bad ntldr or some such - doesn't much matter, the idea is al sorts of disk/file corruption.
I tried unplugging all the SATA and all but one of the PATA drives and re-installing but I still get corruption during the XP install, basically I can't even reconfig the machine.
I've got a feeling some component has gone bad but which one? I've seen this sort of thing before and it turned out to be a bad IDE cable believe it or not. I've reseated all the cables to no avail.
Could it be RAM? CPU? MOBO? I guess it could be any of those.
I don';t have much in the way of extra components to try swapping stuff out, unfortunately.. Thats my main problem.
Anyone seen this symptom recently, and have a clue as to where I should look first?
Thanks in advance for any help
jlanka
jlanka
