Corsair 350D Fan Placement Question
egeerdogan
14
Hi, I have a Corsair Obsidian 350D case running with gtx 770 and intel i5 4670k. I am using two AF 120 Quiet Editions currently, one front and one rear. I wonder if I need two more of the same fans to put on top, if yes, should they suck air in or blow out? No water cooling by the way.
Thanks
What temps are you running with your current setup? If they are within reason, no additional fans are necessary. If you do want to add fans, one should be enough. Set it up as intake (pull in) so as to maintain positive pressure in the case.
Mark
Mark
Thanks. Currently it isn't getting too hot but maybe I can place two fans in front and one at the back when it gets too hot during the summer.
