Corsair 400C using 400Q parts?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
As much as i love my NZXT Phantom 820 case, it's definitely overkill, but then i discovered corsair's 400 series and i love the idea of the sound dampened panels, except i'm leaning more towards the 400C with the window.
Question being, is it possible for me to get the 400C and seperately buy all the other parts from the 400Q that have the sound proofing? or maybe even could i get the 400Q and replace the one side panel with the window?
You can buy the same material that they use on the side panels of the quiet edition of the case, but just do your research on how thick and what type of adhesive you should use.
