Question Corsair 460x RGB and fan connections
Mar 14, 2019
11
I just bought the corsair 460x and the fans dint work. I have to connect all the 3 fans to the motherboard? (gigabyte b450m ds3h)
They connect to the SYS_FAN1 header on the MB.
This is described on page 13 of the manual.
Many times....this header is limited to 1 amp.....so if you decide to use more than one fan (using a splitter) makes sure the total amperage of the fans doesn't go over 1 amp.
Mar 14, 2019
11
I want to use the 3 fans. The thing is that i dont know if my mobo had 3 fan headers :S. I think I made a mistake buying this mobo T_T. Do i need to buy a splitter if this is the case?
