The current setup for mar Corsair 500R is:
Two 120mm front bottom, intake
One 200mm side, intake
One 120mm back top, exhaust
H100i on top (2x 120mm), intake
120mm bottom, intake
Now this is my first build and I don’t think this is optimised and maybe my H100i top fans should be reversed and become exhaust fans as the general rule is in from the bottom/front and out the top/back. However this seemed to say that the H100i should be an intake shown from the link.
http://www.silverstonetek.com/techtalk_cont.php?tid=wh_positive&area=en.
I should also note that soon I will have an extra gigabyte HD 7950 making me have 2 so GPU cooling would be my first priority.
So…
1- What would be the optimal fan layout? Direction, positive or negative etc
2- Should I replace and of the stock 500R fans?
3- Would I require any more additional fans for my two gigabyte 7950 gpu.
My current Build:
Asrock Z77 extreme 4 Motherboard
I5-3570k OC to 4.4 Ghz
Gigabyte HD 7950 OC (core 1090Mhz, Memory 1480Mhz)
Corsair H100i Water cooler
8gb 1866Mhz Ram Patriot Viper 3
256SSD Samsung 840 + 2TB Seagate HDD (7200rpm)
Corsair HX750 Professional Series PSU
Corsair Carbide 500R Micro ATX Midi Tower White
Soon to have an additional gigabyte HD7950
Thanks in advance!
So…
My current Build:
Thanks in advance!
