Hello
I'm almost sure that i'm going for H100i Pro RGB or H115i Pro RGB (i'm not thinking on OC the CPU)
My doubt is, it will be better to use H100i Pro RGB top install or the H115i Pro RGB front install?
Front install will be a factor in terms on tempeture? since the intake air will pass through the radiator prior enter in the case (btw the botton fan of the 3 front fans included in the case will not be "obstructed" by the radiator)
If i go for the H115i Pro RGB (front install) i will add 3 more fans as exhaust, 1 rear and 2 top. Is this a good concept for airflow?
With H100I Pro RGB (top install) i will only add 1 rear fan as exhaust.
CASE: CORSAIR 570X MIRROR
CPU: INTEL® CORE I7-9700K 3.6GHZ/4.9GHZ 12MB LGA 1151
MOTHERBOARD: GIGABYTE Z390 AORUS ULTRA SKT 1151/4XDDR4/HDMI/5 USB 3.1/ ATX
GPU: ZOTAC RTX 2080 AMP! EXTREME ED 8MB GDDR6
RAM: HYPERX PREDATOR 8GB 2666MHZ DDR4 (x2)
HDD: SEAGATE BARRACUDA 2TB 3.5" 7200RPM
SSD: SAMSUNG 970 EVO Plus 250GB M.2
POWER SUPPLY : RMX SERIES RM750X 80 PLUS GOLD FULLY MODULAR ATX POWER SUPPLY
CPU COOLER: (I DON'T KNOW WHICH ONE TO GET)
Ty
Ty
