Corsair 600T case front panel USB port question
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I plan to build a gaming PC with the Corsair 600T mid-tower ATX case. It comes with four USB 2.0 ports and one USB 3.0 port. I would like to replace the USB 2.0 ports with USB 3.0 ports. Can this be done easily or will it void the warranty? Thanks.
Yes it can be done pretty easily depending on the case if you buy a USB 3.0 port you can easily pop out the USB 2.0'port and put in the 3.0 it always depends on the case some have size support for a USB 3.0 replacement most will only fit 2.0 so you will have to cut it out. As for warranty voiding it will with most but some will still have warranty. The benifits of 3.0'are simple faster read write and transfer speeds
