Hello,
First thing is first happy holidays everyone.
Ok to my problem. I have a corsair 600t white. And the fan controller is going bad on it. Corsair wants me to send them the case so they can replace it but I don't want to do that. I don't want to take my computer apart and not have a case for it for several days. I would rather just buy new fans and and plug them into the motherboard or PSU instead of having them connected to a fan controller.
So my question is which fans will fit the 600t? I was thinking of
http://www.frys.com/product/7349164?site=sr:SEARCH:MAIN_RSLT_PG 2 of those 1 intake and 1 exhause 200mm.
OR
http://www.frys.com/product/6208850?site=sr:SEARCH:MAIN_RSLT_PG
OR
http://www.frys.com/product/6233540?site=sr:SEARCH:MAIN_RSLT_PG
For the back 140mm I need to choose one of these:
http://www.frys.com/search?resultpage=0&start=0&rows=25&pType=pDisplay&cat=-69582&inq=140mm&x=0&y=0
Thanks for your help.
I just thought of something. Can you connect the original Corsair fans into the motherboard? Or not into the fan controller? That would probably make them run at full speed all of the time right?
OR
OR
