Hello, all!
I am looking to switching my case from a Lian Li O11 Dynamic EVO to a Corsair 7000D Airflow.
I currently have the following fan configuration:
I am wondering what will be the best fan configuration for myself. Should I keep my GPU AIO as exhaust and place all the fans on the side as exhaust as well and just have the front be the only intakes or should I switch my GPU AIO fans to intake and then utilize the entire front and side as intakes? Or is there a better way to do it?
Thank you all for your help!
- 6x 120mm 360mm AIO push-pull configuration
- 3x 120mm intake on bottom
- 2x 120mm 240mm AIO for my Suprim Liquid X in Exhaust on the Side
- 1 120mm rear fan as Exhaust
