Question Corsair 7000D - Corsair HX1000i (2023) cables question
kisserik93
47
Hello!
I bought a Corsair HX1000i power supply.
In my Corsair 7000D case, unfortunately, the ATX (24PIN) cable just reaches the socket. Is there a longer cable of the same quality as the factory one? How would you solve it?
+ question. Is there a reliable 90 degree 24 pin adapter?
Many people complain about fire damage in the case of cable extensions and adapters.
Thanks!
If you're getting sub-par quality cables then you're inviting problems to the build. You should look into cable extensions or perhaps reach out to folks who cater to custom sleeving with 16AWG for all cables in your build, except for the SATA/molex cables stemming from the PSU.
Looks like the shift would've been a good fit for your case. This dude made it work in his build.
